| Field | DataType | Nullable | Comments |
| REQUEST_IDX | NUMBER | No | AMR request id. PRIMARY KEY |
| EVENT_CLS | NUMBER | No | The class part of the handle of the event for which the AMR request was made. |
| EVENT_IDX | NUMBER | No | The index part of the handle of the event for which the AMR request was made.  |
| REQUEST_TIME | DATE | No | The timestamp when the AMR request was created (in the UTC time zone). |
| WHO_REQUESTED | VARCHAR2(32) | Yes | User name of the operator who created the AMR request. |
| AMR_COMPLETE_TIME | DATE | Yes | The timestamp when the AMR request was completed or canceled (in the UTC time zone). |
| WHO_COMPLETED | VARCHAR2(32) | Yes | User name of the operator who completed or canceled the AMR request. |
| REQUEST_TYPE | NUMBER | Yes | Request type. Possible values: •	1 - PSO Verification •	2 - PDO Verification •	3 - Restoration Verification •	4 - Manual |
| QUERY_TYPE | NUMBER | Yes | Query type. Possible values: •	0 - simple meter status query •	1 - complex meter information query •	100 - voltage query •	101 - phase voltage query Note: Query types with values below 100 are meter status (ping) queries. Query types with values 100 and above are meter read queries. |
| STATUS | NUMBER | Yes | Status of the AMR request. Possible values: 1- active 2 - explicitly completed 3 -cancelled |
| DEVICE_CLS | NUMBER | Yes | The class part of the handle of the device for which the AMR request was made. |
| DEVICE_IDX | NUMBER | Yes | The index part of the handle of the device for which the AMR request was made. |
| NCG | NUMBER | Yes | NCG of the device for which the AMR request was made. |
| TTL | NUMBER(9) | Yes | The Time-To-Live of the request in seconds. |
| ID | Number | No | Unique record identifier. PRIMARY KEY |
| REQUEST_IDX | NUMBER | Yes | AMR request id. |
| REQUEST_TIME | DATE | Yes | Request timestamp (in the UTC time zone). |
| METER_NO | VARCHAR2(256) | Yes | Meter number as known to the AMR system |
| METER_ID | NUMBER | No | NMS meter identifier. |
| REQ_STATUS | VARCHAR2(1) | Yes | Request status. Possible values: •	N - new request (not yet sent to AMR) •	P - pending request (waiting for AMR response) •	S - suppressed request •	R - AMR response received •	C - completed request |
| STATUS | VARCHAR2(256) | Yes | Meter status received from AMR. Possible values: •	ON - meter has power •	OFF - meter does not have power |
| AMR_ERROR | VARCHAR2(256) | Yes | Error message received from the AMR system. |
| RECEIVED_TIME | DATE | Yes | Timestamp when the response was received from the AMR system (in the UTC time zone). |
| RESULT_TIME | DATE | Yes | Timestamp returned by the AMR system for the meter status (in the UTC time zone). |
| PROBABILITY | NUMBER | Yes | The probability of the meter having power (0 - no power; 100 - meter has power.) |
| ATTEMPT_COUNT | NUMBER(3) | Yes | Count of the attempts made to send a request to the AMR system. |
| VOLTAGE | VARCHAR2(16) | Yes | Meter voltage reading. |
| VOLTAGE_A | VARCHAR2(16) | Yes | Meter phase A voltage reading. |
| VOLTAGE_B | VARCHAR2(16)  | Yes | Meter phase B voltage reading. |
| VOLTAGE_C | VARCHAR2(16) | Yes | Meter phase C voltage reading. |
| METER_ID | VARCHAR2(14) | No | Meter identifier in Oracle Utilities Network Management System. |
| METER_NO | VARCHAR2(20) | Yes | Meter identifier used by the AMR system. |
| RESULT_TIME | DATE | Yes | Timestamp of the latest meter status update (in the UTC time zone). |
| POWER_UP_TIME | DATE | Yes | Timestamp of the latest power-up message (in the UTC time zone). |
| LAST_GASP_TIME | DATE | Yes | Timestamp of the latest "last gasp" message (in the UTC time zone). |
| ALT_METER_NO | VARCHAR2(256) | Yes | Alternative meter number. |
| AMR_ENABLED | VARCHAR2(1) | Yes | Indicator that meter is AMR-enabled. |
| STATUS | VARCHAR2(256) | Yes | Latest known meter status. Possible values: •	ON - meter has power •	OFF - meter does not have power |
| REQUEST_IDX | NUMBER | Yes | AMR request id for the latest received meter status. |
| PROBABILITY | NUMBER | Yes | Latest known probability of the meter having power (0 – no power; 100 – meter has power). |
| BELLWETHER | VARCHAR2(1) | Yes | Bellwether meter flag (Y/N) |
| METER_PHASES | VARCHAR2(1) | Yes | Meter phase/multiphase meter flag. |
| VOLTAGE_ THRESHOLD | NUMBER | Yes | Meter low voltage threshold. |
| METER_HIST_ID | NUMBER | No  | Primary key (sequence generated). |
| METER_ID | NUMBER | Yes | NMS meter identifier. |
| METER_NO | VARCHAR2(256) | Yes | Meter number specific to the AMR system. |
| RESULT_TIME | DATE | Yes | Meter read time (in the UTC time zone). |
| VOLTAGE | NUMBER | Yes | Meter voltage. |
| VOLTAGE_A | NUMBER | Yes | Phase A meter voltage. |
| VOLTAGE_B | NUMBER | Yes | Phase B meter voltage. |
| VOLTAGE_C | NUMBER | Yes | Phase C meter voltage. |
