| Field | Description |
| EVENT_IDX | Event index. Primary key. |
| EXTERNAL_ID | Event's external id. |
| DEVICE_CLS | Class part of the event's device handle. |
| DEVICE_IDX | Index part of the event's device handle. |
| PHASES | Affected device phases. |
| STATUS | Event's condition status (PSO, PDO, etc.) |
| STATE_KEY | Event's state key. |
| NUM_CUST_OUT | Number of affected customers. |
| NUM_CALLS | Number of customer calls. |
| TROUBLE_CODE | Event's trouble code (combination of the unique trouble codes of the customer calls). |
| ERT | Estimated restoration time. |
| COMMENTS | Event comments. |
| LAST_UPDATE_TIME | Last update time (in the UTC time zone). |
| ACTIVITY_ID | Activity identifier. Primary key. Generated by the adapter. |
| EXTERNAL_ID | OFS identifier of activity. |
| EVENT_IDX | NMS event index. Foreign key into the OMS_MWM_EVENTS table. |
| CREW_ID | Crew id/name. |
| CREW_TYPE | Crew type. Only populated if in NMS a generic crew is assigned to the activity. |
| STATUS | Activity status. Valid values: •	INITIAL - initial state for activities created by NMS •	NO_CREW - activity without a crew •	DISPATCHED - activity has been given to a crew •	DISPATCHED_ACK - crew has accepted the activity •	EN_ROUTE - crew is en-route to work location •	ARRIVED - create has arrived at the work location but haven't started the work •	STARTED - crew has started the work •	SUSPENDED - crew has temporarily suspended this activity •	COMPLETE - activity is completed •	CANCELLED - activity is cancelled |
| PENDING | 'Pending flag (Y means that this activity should not be cancelled when crew is released). It is set when an activity is created from the OFS without a crew. |
| CREATED | Activity creation time. |
| COMPLETED | Activity completion/cancellation time. |
| ALARM_IDX | Alarm index.  Primary key. |
| ACTIVITY_ID | Activity identifier. Foreign key into the OMS_MWM_ACTIVITIES table. |
| SENT_TIME | Time when the alarm was sent to mobile system (in the UTC time zone). |
| ID | Primary key.  Generated by the sequence OMS_MWM_CREW_ACTIONS_SEQ. |
| EXTERNAL_ID | External identifier. Should be unique for the rows associated with the same trouble event. |
| EVENT_IDX | Event index. |
