Switching and Safety Web Service
There are two versions of this web service. One uses rpc-literal style and the other uses document-literal style. Both versions provide the same set of operations.
Port SwmanServiceBeanPort
Location: https://<nms host>:<nms port>/ExternalSwmanServiceImpl/SwmanServiceBean
Protocol: SOAP
Encoding style: rpc
Transport protocol: SOAP over HTTP
Target Namespace: http://www.oracle.com/ugbu/nms
Port SwmanServiceDocBeanPort
Location: https://<nms host>:<nms port>/ExternalDocSwmanServiceImpl/SwmanServiceDocBean
Protocol: SOAP
Encoding style: document
Operations
GetSafetyDocument
Retrieves safety document by handle.
Operation Type: Request-response. The endpoint receives a message, and sends a correlated message.
Input: GetSafetyDocument (soap:body, use = literal)
	docHdl type handle
	Safety document handle.
Output: GetSafetyDocumentResponse (soap:body, use = literal)
	safetyDoc type SafetyDoc
	Safety document
•	id - nillable; type long
	Safety document identifier
•	externalId - optional; type normalizedString
	Safety document external identifier
•	handle - nillable; type handle
•	docType - nillable; type normalizedString
	Safety document type
•	state - optional; type State
	Real-time state
•	swSheet - optional; type handle
	Switching sheet handle
•	deleted - optional; type boolean
	Safety document deleted flag
•	version - optional; type long
	Safety document version (used for optimistic locking)
•	extensions - optional; type ArrayOfExtensionField
	Extension fields
•	steps - optional; type ArrayOfSwStep
	Switching steps associated with this safety document
•	step - optional, unbounded; type SwStep
	Switching step
•	cls - nillable; type long
	Switching step class
	Switching step identifier
•	parentId - optional; type long
	Parent step
•	groupNumber - optional; type long
	Group number
•	device - optional; type handle
	Handle of the main device associated with this switching step
•	deviceAlias - optional; type normalizedString
	Alias of the main device associated with this switching step
•	controlZone - optional; type ControlZone
	Switching step control zone
•	phases - optional; type phaseCode
	Phases of the main device affected by this switching step
•	availablePhases - optional; type phaseCode
	All phases of the main device associated with this switching step
•	secondaryDevice - optional; type handle
	Handle of the secondary device associated with this switching step
•	groundNode - optional; type handle
	Grounding node associated with this switching step
•	condition - optional; type handle
	Condition associated with this switching step
	Switching step real-time state
•	controlAction - optional; type ControlAction
	Control Tool action
•	action - nillable; type normalizedString
•	switchingCode - optional; type normalizedString
•	attribute - optional; type long
[a]	cls - required; type normalizedString
[a]	idx - required; type normalizedString
[a]	key - required; type long
	Switching step control action
•	revision - optional; type long
	Switching step revision number
•	description - optional; type string
	Description
•	comments - optional; type string
	Comments
•	plannedOffset - optional; type duration
	Planned offset
•	createTime - optional; type dateTime
	Date/time when this step was created
•	createUser - optional; type normalizedString
	User who created this step
•	updateTime - optional; type dateTime
	Date/time when step was last updated
•	updateUser - optional; type normalizedString
	User who made the latest update this step
•	instructTime - optional; type dateTime
	Date/time when step was instructed
•	instructUser - optional; type normalizedString
	User who instructed this step
•	executeTime - optional; type dateTime
	Date/time when step was executed
•	executeUser - optional; type normalizedString
	User who executed this step
•	executeOrder - optional; type long
	Step execution order
•	operationOutcome - optional; type normalizedString
	Operation outcome
•	undoOperationOutcome - optional; type normalizedString
	Undo operation outcome
•	resultOfOperation - optional; type normalizedString
	Result of operation
•	resultFeeders - optional; type normalizedString
	Result feeders
•	lastResultOfOperation - optional; type normalizedString
	Last result of operation
•	editedOperation - optional; type normalizedString
	Edited operation
•	modelBuild - optional; type normalizedString
	Step affected by model build
•	safetyDocId - optional; type long
	Safety document id (for safety-related steps)
•	safetyDevStatus - optional; type normalizedString
	Status of the device as it pertains to the associated safety document. This is used to keep track of a user's modifications to a safety document's device list. ADD - The device has been added as part of a viewer device selection. ADD_STEP - The device has been added as part of a switching sheet step association. COND_APPLIED - The condition has been applied and updated to the device in the device list. INCOMPLETE - The device is associated to a switching step where the condition has already been applied to the device. REMOVE - The device has been marked for removal and will be removed the next time the document transitions from the Unissued to Issued state. REMOVED - The device has been removed from the device list. These devices are filtered out of the device list.
•	safetyCondAdded - optional; type long
	Safety document version number where this safety condition step was added
•	safetyCondRemoved - optional; type long
•	crews - optional; type ArrayOfCrewId
	Crew ids
	Extension fields
•	crews - optional; type ArrayOfSafetyCrew
	Crew information associated with this safety document
•	crew - optional, unbounded; type SafetyCrew
	Crew information associated with a safety document
•	crewId - optional; type normalizedString
	Crew id
•	position - optional; type normalizedString
	Position the crew is in with regards to the zone of protection
•	auditLog - optional; type ArrayOfAuditLogEntry
	Audit log entries
•	log - optional, unbounded; type AuditLogEntry
	Audit log entry
	Audit log entry identifier
•	entryType - optional; type normalizedString
	Audit log entry type
•	userLog - optional; type string
	User log
	Device handle
	Device alias
	State
	Revision number
•	comment - optional; type string
	Log comment
	Phases
	Crew ids
Fault: OmsServiceException (soap:fault, use = literal)
	fault type OmsServiceException
GetSafetyDocumentsForSheet
Retrieves all safety documents for a switching sheet.
Input: GetSafetyDocumentsForSheet (soap:body, use = literal)
	sheetHdl type handle
	Switching sheet handle.
Output: GetSafetyDocumentsForSheetResponse (soap:body, use = literal)
	safetyDocs type ArrayOfSafetyDoc
	List of safety documents
•	safetyDoc - optional, unbounded; type SafetyDoc
	Safety document (see GetSafetyDocument)
GetSwitchingSheet
Retrieves switching sheet by handle.
Input: GetSwitchingSheet (soap:body, use = literal)
Output: GetSwitchingSheetResponse (soap:body, use = literal)
	swSheet type SwSheet
	Switching sheet
	Switching sheet identifier
	Switching sheet external identifier
	Handle of the main device associated with this switching sheet
	Alias of the main device associated with this switching sheet
	Switching sheet control zone
•	owner - optional; type normalizedString
	Switching sheet owner
	Switching sheet revision number
•	version - nillable; type long
	Switching sheet version (used for optimistic locking)
•	checkedIn - optional; type normalizedString
	Switching sheet is checked in
	Real-time state
	Date/time when this sheet was created
	User who created this sheet
	Date/time when this sheet was last updated
	User who updated this sheet last
•	lockedTime - optional; type dateTime
	Date/time when sheet was locked
•	lockedUser - optional; type normalizedString
	User who locked this sheet
•	startTime - optional; type dateTime
	Date/time when execution of this switching sheet is expected to start
•	finishTime - optional; type dateTime
	Date/time when execution of this switching sheet is expected to finish
•	completedTime - optional; type dateTime
	Completion date/time
•	reworkDescription - optional; type string
	Rework description
•	reworkTime - optional; type dateTime
	Rework date/time
•	defaultOffset - optional; type duration
	Default offset
	Switching sheet is affected by model build
	Extension fields
	Switching steps
	Switching step
	Parent step
	Group number
	Control tool action
	Description
	Comments
	Planned offset
	Operation outcome
	Result of operation
	Result feeders
	Edited operation
	Crew ids
	Extension fields
	Audit log entries
	Audit log entry
	User log
	Device handle
	Device alias
	State
	Revision number
	Log comment
	Phases
	Crew ids
•	standaloneSafetyDoc - optional; type SafetyDoc
createSwmanSheetFromExternalSystem
Creates new or updates an existing switching sheet.
Input: createSwmanSheetFromExternalSystem (soap:body, use = literal)
	dataString type string
	XML representation of the switching sheet.
	Output: createSwmanSheetFromExternalSystemResponse (soap:body, use = literal)
	return type int
	Return code.
sheetStateTransition
Executes state transition on a switching sheet.
Input: sheetStateTransition (soap:body, use = literal)
	actionType type string
	State transition action type.
	actionName type string
	State transition action name.
	username type string
	Username.
Output: sheetStateTransitionResponse (soap:body, use = literal)
