Damage Assessment Web Service
Oracle Utilities Network Management System Damage Assessment web service
Port DamageServiceSOAP
Protocol: SOAP
Default style: document
Transport protocol: SOAP over HTTP
Target Namespace: http://oms.splwg.com/ws/damage/
Operations
CompleteDamageReport
Completes an existing damage report.
Operation Type: Request-response. The endpoint receives a message, and sends a correlated message.
SOAP Action: http://oms.splwg.com/ws/damage/CompleteDamageReport
Input: CompleteDamageReportRequest (soap:body, use = literal)
parameters type CompleteDamageReport
	reportId type long
	Damage report id
Output: CompleteDamageReportResponse (soap:body, use = literal)
parameters type CompleteDamageReportResponse
	report type damageReport
	Damage assessment report
•	id - optional; type long
	Damage report unique identifier assigned by the server
•	groupable - optional; type boolean
	 Allow this damage report to be grouped upstream
•	externalId - optional; type string
	External id of the damage assessment incident in NMS
•	eventIdx - optional; type int
	Index of the event associated with this damage report
•	eventExternalId - optional; type string
	External id of the event associated with this damage report
•	patrolEventIdx - optional; type int
		Index of the patrol event associated with this damage report
•	device - optional; type handle
[a]	cls - required; type short
[a]	index - required; type int
[a]	app - optional; type short
	Handle of the affected device
•	deviceAlias - optional; type string
	Alias of the affected device
•	feeder - optional; type string
	Feeder name
•	gpsLocation - optional; type gpsLocation
	GPS location
•	latitude type double
	Latitude
•	longitude type double
	Longitude
	GPS location of the damage
•	zone - optional; type string
•	grid - optional; type string
•	location - optional; type string
•	section - optional; type string
•	city - optional; type string
•	address - optional; type string
	Street address of the damage
•	phases - optional; type phaseCode - type string with restriction - enum { 'NONE', 'A', 'B', 'AB', 'C', 'AC', 'BC', 'ABC', 'N', 'AN', 'BN', 'ABN', 'CN', 'ACN', 'BCN', 'ABCN', 'Unknown' }
	Affected phases
•	loadAffected - optional; type boolean
	Is damage causing an outage
•	roadBlocked - optional; type boolean
		Is road blocked
•	streetLightDamage - optional; type boolean
		Is street light damage reported
•	hazardous - optional; type boolean
		Is damage hazardous
•	crew - optional; type crew
[a]	id - required; type string
	NMS crew identifier (crew name)
[a]	mobileNumber - optional; type string
	Crew's mobile (radio) number
	Crew, who submitted this damage report
•	stateName - optional; type string
	Damage report state (New, Assessed, etc.)
•	stateBitmask - optional; type int
	Damage report state bitmask (New=0x1, Assessed=0x2, Complete=0x4, Obsolete=0x8)
•	active - optional; type boolean
•	reportTime - optional; type dateTime
•	lastModified - optional; type dateTime
•	version - optional; type long
	Damage report version used for optimistic concurrency control
•	damageType - optional, unbounded; type reportDamageType
•	typeId type int
•	typeName - optional; type normalizedString
•	accessible - optional; type int
•	inaccessible - optional; type int
	List of specific damage instances
•	damageComment - optional; type string
•	requiredPart - optional, unbounded; type reportDamagePart
•	quantity - optional; type int
•	partId type string
	List of required parts/materials needed to address reported damage
•	requirePartsComment type string
•	crewType - optional, unbounded; type crewType
•	id type int
	Crew type id
•	name type string
	Crew type name
	List of crew types needed to address reported damage
•	miscField1 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_TEXT1
•	miscField2 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_TEXT2
•	miscField3 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_TEXT3
•	miscField4 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_TEXT4
•	miscField5 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_TEXT5
•	miscField6 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_OPTION1
•	miscField7 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_OPTION2
•	miscField8 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_OPTION3
•	miscField9 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_OPTION4
•	miscField10 - optional; type string
	Mapped to database column DAMAGE_REPORT.MISC_OPTION5
•	udf1 - optional; type string
		User-defined field 1
•	udf2 - optional; type string
		User-defined field 2
•	udf3 - optional; type string
		User-defined field 3
•	udf4 - optional; type string
		User-defined field 4
•	udf5 - optional; type string
		User-defined field 5
•	udf6 - optional; type string
		User-defined field 6
•	udf7 - optional; type string
		User-defined field 7
•	udf8 - optional; type string
		User-defined field 8
•	udf9 - optional; type string
		User-defined field 9
•	udf10 - optional; type string
		User-defined field 10
•	udf11 - optional; type string
		User-defined field 11
•	udf12 - optional; type string
		User-defined field 12
•	udf13 - optional; type string
		User-defined field 13
•	udf14 - optional; type string
		User-defined field 14
•	udf15 - optional; type string
		User-defined field 15
•	udf16 - optional; type string
		User-defined field 16
•	udf17 - optional; type string
		User-defined field 17
•	udf18 - optional; type string
		User-defined field 18
•	udf19 - optional; type string
		User-defined field 19
•	udf20 - optional; type string
		User-defined field 20
•	attachment - optional, unbounded; type attachment
	List of damage report attachments. Actual attachment data is not included.
•	data - optional; type base64Binary
	Attachment data
•	description - optional; type string
	Description of the attachment
	Attachment id (file name)
[a]	reportId - required; type long
	Damage report id
[a]	uri - optional; type anyURI
	Link to the attachment. Can be used instead of passing attachment data in the message
[a]	contentType - optional; type string
	MIME content type
[a]	lastModified - optional; type dateTime
	Last modification timestamp
Fault: DamageServiceException (soap:fault, use = literal)
parameters type DamageServiceFault
	errors - unbounded; type Error
	Damage Service error
•	error type errorCode - type string with restriction - enum { 'CreateFailed', 'CompletedEvent', 'UnknownEvent', 'BadEventType', 'LoadAffectedSetForNonOutage', 'DatabaseError', 'UnknownReportId', 'AlreadyCompleted', 'StaleData', 'IncidentCreateFailed', 'InvalidCrewType', 'InvalidDamageType', 'InvalidRequiredPart', 'NeedEventOrDevice', 'NeedAddress', 'NeedCrewId', 'MoveFailed', 'AttachmentTooBig', 'AttachmentSaveError', 'AttachmentNotFound', 'Other' }
	String representation of the error code
[a]	code type int
	Error code
[a]	reportId type long
	Damage report id associated with the error
DeleteAttachments
Deletes one or more damage report attachments.
SOAP Action: http://oms.splwg.com/ws/damage/DeleteAttachments
Input: DeleteAttachmentsRequest (soap:body, use = literal)
parameters type DeleteAttachments
	attachmentId - unbounded; type attachmentId
	Identifier for damage report attachment
•	id type string
	Attachment id (file name). If empty then all attachments for this damage report are included.
•	reportId type long
	Damage report id
Output: DeleteAttachmentsResponse (soap:body, use = literal)
[a]	code type int
	Error code
GetAttachments
Retrieves damage report attachments.
SOAP Action: http://oms.splwg.com/ws/damage/GetAttachments
Input: GetAttachmentsRequest (soap:body, use = literal)
parameters type GetAttachments
•	id type string
	Damage report id
Output: GetAttachmentsResponse (soap:body, use = literal)
parameters type GetAttachmentsResponse
	result - optional, unbounded; type attachment
[a]	data - optional; type base64Binary
	Attachment data
[a]	description - optional; type string
•	id - required; type string
•	reportId - required; type long
	Damage report id
•	uri - optional; type anyURI
•	contentType - optional; type string
	MIME content type
•	code type int
	Error code
GetCrewTypes
Returns all crew types configured in NMS.
SOAP Action: http://oms.splwg.com/ws/damage/GetCrewTypes
Input: GetCrewTypesRequest (soap:body, use = literal)
parameters type GetCrewTypes
Output: GetCrewTypesResponse (soap:body, use = literal)
parameters type GetCrewTypesResponse
	result - optional, unbounded; type crewType
•	id type int
	Crew type id
•	name type string
	Crew type name
[a]	error type errorCode - type string with restriction - enum { 'CreateFailed', 'CompletedEvent', 'UnknownEvent', 'BadEventType', 'LoadAffectedSetForNonOutage', 'DatabaseError', 'UnknownReportId', 'AlreadyCompleted', 'StaleData', 'IncidentCreateFailed', 'InvalidCrewType', 'InvalidDamageType', 'InvalidRequiredPart', 'NeedEventOrDevice', 'NeedAddress', 'NeedCrewId', 'MoveFailed', 'AttachmentTooBig', 'AttachmentSaveError', 'AttachmentNotFound', 'Other' }
•	code type int
	Error code
GetDamageReportById
Returns damage report for given report id.
SOAP Action: http://oms.splwg.com/ws/damage/GetDamageReportById
Input: GetDamageReportByIdRequest (soap:body, use = literal)
parameters type GetDamageReportById
	reportId type long
	Damage report id
Output: GetDamageReportByIdResponse (soap:body, use = literal)
parameters type GetDamageReportByIdResponse
	Damage assessment report (see CompleteDamageReport)
•	code type int
	Error code
GetDamageReportsByHandle
Returns all damage reports for given event or device handle.
SOAP Action: http://oms.splwg.com/ws/damage/GetDamageReportsByHandle
Input: GetDamageReportsByHandleRequest (soap:body, use = literal)
parameters type GetDamageReportsByHandle
	handle type handle
•	cls - required; type short
•	index - required; type int
•	app - optional; type short
	Event or device handle
Output: GetDamageReportsByHandleResponse (soap:body, use = literal)
parameters type GetDamageReportsByHandleResponse
	report - optional, unbounded; type damageReport
•	code type int
	Error code
GetDamageReportsByPatrol
Returns all damage reports for given patrol event index.
SOAP Action: http://oms.splwg.com/ws/damage/GetDamageReportsByPatrol
Input: GetDamageReportsByPatrolRequest (soap:body, use = literal)
		parameters type GetDamageReportsByPatrol
			patrolEventIdx type int
				Patrol event index
Output: GetDamageReportsByPatrolResponse (soap:body, use = literal)
		parameters type GetDamageReportsByPatrolResponse
•	code type int
				Error code
•			• reportId type long
GetRequiredParts
Returns all required parts/materials configured in NMS.
SOAP Action: http://oms.splwg.com/ws/damage/GetRequiredParts
Input: GetRequiredPartsRequest (soap:body, use = literal)
parameters type GetRequiredParts
Output: GetRequiredPartsResponse (soap:body, use = literal)
parameters type GetRequiredPartsResponse
	result - optional, unbounded; type requiredPart
•	id type string
•	name type string
•	source - optional; type string
•	code type int
	Error code
NewDamageReport
Returns populated damage report for given event or device. This operation does not create new damage report in NMS.
SOAP Action: http://oms.splwg.com/ws/damage/NewDamageReport
Input: NewDamageReportRequest (soap:body, use = literal)
parameters type NewDamageReport
	handle - optional; type handle
	Device alias (only used if handle is not provided)
	Event's external id (only used if handle is not provided)
Output: NewDamageReportResponse (soap:body, use = literal)
parameters type NewDamageReportResponse
•	code type int
	Error code
SaveAttachments
Creates new or updates existing damage report attachments.
SOAP Action: http://oms.splwg.com/ws/damage/SaveAttachments
Input: SaveAttachmentsRequest (soap:body, use = literal)
parameters type SaveAttachments
	attachment - unbounded; type attachment
	Attachment data
	Damage report id
	MIME content type
Output: SaveAttachmentsResponse (soap:body, use = literal)
•	code type int
	Error code
SaveDamageReport
Creates new or updates existing damage report. This operation cannot be used to complete an existing damage report.
SOAP Action: http://oms.splwg.com/ws/damage/SaveDamageReport
Input: SaveDamageReportRequest (soap:body, use = literal)
parameters type SaveDamageReport
	action - optional; type string
	Action to trigger state transition
Output: SaveDamageReportResponse (soap:body, use = literal)
parameters type SaveDamageReportResponse
•	code type int
	Error code
GetRepairTimeConfig
Returns damage assessment repair time configuration.
SOAP Action: http://oms.splwg.com/ws/damage/GetRepairTimeConfig
Input: GetRepairTimeConfigRequest (soap:body, use = literal)
	parameters type GetRepairTimeConfig
Output: GetRepairTimeConfigResponse (soap:body, use = literal)
parameters type GetRepairTimeConfigResponse
	result - optional, unbounded; type damageRepairTime
•	assetType type string
•	accessibleRepairTime type int
•	inaccessibleRepairTime type int
•	deviceClass type int
•	code type int
	Error code
