Name | Data Type | Description |
parameter_name | VARCHAR2(32) | The name of the parameter. Required. |
parameter_value_1 | VARCHAR2(64) | Required parameter value. |
parameter_value_2 | VARCHAR2(64) | Optional parameter value. |
parameter_value_3 | VARCHAR2(64) | Optional parameter value. |
Parameter | Description |
sourceDBServiceName | Sets the database service name, server name, and port details for the forecast updates table. • parameter_value_1: server name. The default value is DB. • parameter_value_2: port number. • parameter_value_3: database service name. |
operationalService | Sets whether the adapter is running on the operational service network or the enterprise service network. • parameter_value_1: Yes | No • Yes: operational service network • No: the enterprise service network |
useSqlLoader | Sets whether to use SQL Loader or NMS Import to load the data into NMS tables. • parameter_value_1: Yes | No • Yes: SQL Loader • No: NMS Import or other process |
forecastDir | The directory containing the forecast CSV file. |
numDataCol | Define rule to specify the number of columns in raw CSV |
dermsColumnMap | Defines the CSV columns. • parameter_value_1: column name. • parameter_value_2: column number. The column numbering starts with 0, which is the first column in the table. The standard configuration is defined as follows: • Column 0 = ForecastDate (mm/dd/yyyy HH24:MI:SS) • Column 1 = ResourceName • Column 2 = PowerSourceType • Column 3 = ForecastValue |
headerPresent | Sets whether the CSV file has a header row or not. • parameter_value_1: Yes | No |
forecastnumDataCol | Define rule to specify the number of columns in External Load and Gen CSV file |
forecastColumnMap | Defines the CSV columns for External Load and Gen CSV file • parameter_value_1: column name. • parameter_value_2: column number. The column numbering starts with 0, which is the first column in the table. The standard configuration is defined as follows: • Column 0 = ForecastDate (mm/ • dd/yyyy HH24:MI:SS) • Column 1 = ResourceName • Column 2 = ForecastSource • Column 3 = Forecastobject • Column 4 = ForecastkW • Column 5 = ForecastkVAR |
