High-Level Messages
The Oracle Utilities Network Management System - Oracle Field Service Adapter responds several commands sent as high-level messages.
High-level message can be sent using Action command-line utility.
Action any.publisher* ejb client NMS-OFS command <message>
Following messages are supported:
RELOAD: Forces adapter to reload configuration and then initiates synchronization sequence.
RESYNC: Initiates synchronization sequence.
STOP: Temporarily stops the adapter.
START: Re-starts previously stopped adapter.
GETCREW <crew name>: Initiate crew composition request for the specified crew. The adapter will send GETCREW_RESPONSE high-level message, containing crew name, to all Crew Info tools, once response is received.
