Oracle Configuration
The following database settings are suggested for at least a minimum level of performance for an Oracle database. Any of these suggestions can be disregarded if an experienced Oracle DBA determines that other settings may offer better overall system performance. However, if any changes are made to any suggested parameters, performance of the system may be affected.
Indexes
Indexes should not be placed on the same physical disk as the data resides. If disk striping is being used then this requirement is not as critical, and may be ignored if enough disks are being employed.
Oracle Text (context) indexes for viewer searches should be optimized periodically, especially after initially loading a model, or after extensive model changes. By default, there is only one context index on alias_mapping.
To optimize this, run this script:
ISQL -admin -silent <<<"exec CTX_DDL.OPTIMIZE_INDEX('ALIAS_MAPPING_CONTEXT','FULL');"
Generating Statistics
As mentioned in a previous section of this chapter, tables should be analyzed periodically. The frequency can be determined by an experienced DBA, but it is suggested that this be done when the model or outage data changes substantially. This ensures that the Oracle statistics will be kept up to date for all of the database tables.
While most tables may be analyzed any time, some tables are cleared and repopulated while services are running. These tables should not be analyzed as part of a batch process; instead, they should be analyzed only while fully populated.
The following tables should only be analyzed after a full set of Feeder Load Management forecasts:
• flm_cap_bank_details
• flm_dev_violations_warnings
• flm_dist_gen_details
• flm_equiv_source_details
• flm_fdr_load
• flm_fdr_load_details
• flm_fdr_tie_points
• flm_feeders
• flm_islands
• flm_model_errors
• flm_reg_transfmr_details
• flm_solutions
Make Tablespaces Locally Managed
Dictionary managed tablespaces are more expensive on performance. It is suggested that the Oracle Utilities Network Management System tablespaces be setup as locally managed.
Block Size
The disk block size of the database should be the default of 8K, but could be set larger on recommendations from an experienced DBA.
Compatibility
An Oracle Utilities Network Management System schema is not backward compatible with Oracle Utilities Network Management System applications. Schema changes occur and are modified as the code and database move forward in time.
For example, it is unlikely that a database which has been migrated or built at version 1.7.10 code level will work with version 1.8.0 code level. However, data models are forward compatible, because Oracle Utilities Network Management System applications can migrate the database forward, making the necessary changes.
Thus, when backing up the database, you should note the Oracle Utilities Network Management System release level that was last operating against the database dump. That way, if there are other systems with older code, the data model is not imported into those systems and problems are not introduced.
Software
The Oracle Utilities Network Management System software is likely to be the most static data on the system. It should only be changing with upgrades. The need for software backup is generally low if the software is installed on several machines locally, but a weekly backup may be needed if there are maintenance scripts and SQL files being updated.
Map Files
Map files are replicated on a number of machines throughout the network, but they will change frequently. Data model files should be backed up once per week at minimum or nightly for frequently changing files.
