Recommended Configuration Order
This section outlines the steps necessary to configure the NMS Monitor, NMS Agents, and HAMI. However, there are some configuration dependencies between each of these components. Specifically, the identity stores and trust stores of the NMS Monitor and NMS Agent nodes need to exist before each other’s certificates can be imported. Below is a recommended order when configuring these nodes with links to the sections describing the process:
1. Switchover/failover scripts
2. HAMI
3. NMS Monitor
4. NMS Agent
5. NMS Monitor
