Power Flow Services High Level Messages and Command Line Options
High level messages are available for data maintenance and troubleshooting.
Note: Oracle recommends that you check with Oracle Support before using these options for the first time - especially in a production environment. They could have unintended consequences for application functionality, performance, or environment resource consumption.
The following Action commands are accepted by DMSService using the form:
Action any.DMSService <command> <options>
• dump [<resource>]: Dump various internal data stores, as determined by <resource>. If no resource is given, then the configuration rules are reported.
• measures: Dump SCADA measurement information for all devices.
• memstats: Dump memory statistics.
• nsm: Dump NSM statistics.
• island <hdl>: Dump contents of island containing <hdl>.
• feeder <hdl>: Dump contents of island containing <hdl>.
• feederstatus: Dump feeder status.
• reload: Reload configuration rules.
• reload_rules: Reload configuration rules.
• processintervaldata: Reload Xfmr profile data.
• process_dms_feeders: Reload the DMS Feeder Status data.
• validate_network: Report on Powerflow Model data.
• dump_model <device> [session]: Topology dump of island containing device
• island_report: Dump a status report about island solutions.
• clear_scada: Clear DMSService of all SCADA updates.
• reset_dgs: Clear all temporary Distributed Generation conditions.
• show_scada <device>: Display SCADA measurements for a device.
• np_emulate [on|off|0|1]: Set Network Protector mode to on (1) or off (0). Mode toggles if no option given.
• what <dev hdl | dev alias>: Report PowerFlow and topology status of device.
• study_what session <dev hdl>: Report PowerFlow and topology status of device in study session.
• debug [FACILITY} <level>: Set debug reporting level for any of the following facilities:
• DBS: Report database related activity.
• EMULATOR: Emulator only based activity.
• FLA: Report FLA related activity.
• FLISR: Report FLISR related activity.
• FLM: Report FLM related activity.
• FLOW: Report Nominal Flow Direction calculations.
• LOCKS: Report Lock/Mutex handling.
• LOADPROFILE: Report Xfmr profile handling.
• MEASURES: Report SCADA related activity.
• MEMSTATS: Report memory usage at significant events.
• MESSAGES: Report messages.
• MODEL: Report Model import, build and update actions.
• PFSOLVE: Report Power Flow solution activity.
• SEGMENT: Report island rebuilding actions.
• SOLVE: Report topology solution activity.
• SS: Report Suggested Switching activity.
• VV: Report Volt/VAr activity.
• TIMING: Report function timing.
• SHARED_MEM: Report shared memory activity.
Note: If a facility is not specified, you can turn debug on for all of them using Action any.NameService debug <level>.
• debug_device <device>: Enable debug information for device.
• stop_and_free [core]: Free all memory, and stop [optionally produce core file].
• processcatalogs: Reload device rating catalogs.
• resolve: Resolve the current solution.
• flisr <command>
• dump: Dump FLISR status information.
• alarms: Perform the daily reminders about disabled devices.
• mode <newMode>: Set the system wide mode for FLISR to one of the following:
• disable: Disabled
• manual: Manual
• automatic: Automatic
• device_disable <dev hdl> <user>: Disable the device for FLISR processing.
• device_enable: <dev hdl> <user>: Re-enable the device for FLISR processing.
• flm <command>
• reforecast: Re-execute all future FLM forecasts.
• hourlyTimer: Perform the top of the hour tasks.
• stop: Stop forecasting.
• start: Restart forecasting.
• feeder_ca <command>: Control N-1 feeder contingency analysis.
• start <runtime>: Start analysis, run for <runtime> minutes (default 60).
• stop: Stop feeder contingency analysis.
• feeder_da <command>: Control feeder data analysis.
• start [runtime]: Start data analysis, run for <runtime> minutes (default 60).
• stop: Stop feeder data analysis.
• purge_fca: purge all of the existing Feeder Contingency Analysis results.
• purge_fda: purge all of the existing Feeder Data Analysis results.
• solve_island <device>: Solve island containing <device hdl>.
• dump_disabled_islands: Report list of islands disabled by FLM.
• reenable_island <src hdl>: Re-enable a specific island.
• reenable_island: Re-enable all non-convergent islands.
• disable_island <src hdl>: Disable a specific island.
• messagestat <command>: Control PFS message statistics.
• print: Report statistics on DMSService message usage.
• reset: Reset message counters to zero.
• vvo_current: Initiate VVO current (fast cycle) execution.
• vvo_hourly: Initiate VVO hourly (slow cycle) execution.
• vvo_update_plan <event hdl>: Force an update on VVO plan for a passed event handle.
DMSService Command Line Options
• -no_alarms: Prevent generation of system alarms when FLM detects Feeder abnormal conditions.
• -allowAutoFlisrStartup: Allow FLISR to startup in automatic mode.
