Configuring Secure FEP Connections
To configure secure communications between the DRMS system and the FEP, configure the keystore and truststore in WebLogic as follows:
1. Open the WebLogic Server Administration Console.
2. Select Servers and choose the server hosting DRMS.
3. Select Keystores.
4. Set the Keystores option to either Custom Identity and Java Standard Trust or Custom Identity and Custom Trust.
5. Enter the Custom Identity Keystore location, type, passphrase, and then confirm the passphrase. The custom identity keystore must contain the public and private keys of the WebLogic server.
6. Enter the Trust Keystore details. If using Java Standard Trust, the location and type are automatically set to $JAVA_HOME/jre/lib/security/cacerts. If the truststore is located elsewhere, select the Custom Identity and Custom Trust option. The trust keystore must contain the Certificate Authority (CA) certificate used to sign the FEP's public keys under the alias specified in the DRMS_FEPS table.
7. Click Save.
8. Select the SSL tab.
9. Enter the Private Key Alias corresponding to the private key stored in the Custom Identity Keystore.
10. Enter and confirm the Private Key Passphrase.
11. Click Save.
