Managing DERMS DER Groups
Working with the DERMS DER Group Management Tool
The DERMS DER Group Management tool allows you to create groups of devices to monitor and to (potentially) modify multiple devices at a time.
Actions
Create Group: Displays the Create/Edit Group dialog box. This allows you to Add a group name, description, and criteria to define the group.
Edit: Displays the Create/Edit Group dialog box that allows you to modify the group definition fields.
View Details: Displays the Group Details page that aggregates power information for the devices and allows you to view the list of devices themselves.
Delete: Deletes the group.
Refresh: Refreshes the data from the database.
Working with the DERMS Smart Inverters Tool
Groups Tab
Lists the groups created by the DERMS DER Group Management tool that include Smart Inverters
Actions
Add Smart Inverter Program: Allows you to add a Smart Inverter program, with a set of available Default and Override controls for the group of devices.
Edit: Allows you to edit the Smart Inverter program.
View Details: Displays the Group Details page.
Create/Edit Event: Displays the Create/Edit Smart Inverter Event tool. This allows you to schedule the Default or Override controls.
Controls Tab
Actions
Create: Displays the Create/Edit Control drawer. This allows you to create a set of Override or Default Controls.
Clone: Allows you to copy the selected Control
Edit: Displays the Create/Edit Control drawer.
Delete: Deletes the selected Control.
Curves Tab
Actions
Create: Displays the Create/Edit Curve drawer. This allows you to create a set of curves for use in Controls.
Clone: Allows you to copy the selected curve.
Edit: Displays the Create/Edit Curve drawer.
Delete: Deletes the selected curve.
