To Do Type - Main
The Main page is used to define basic information about a To Do type.
To maintain this information, select > > .
CAUTION:
Important! If you introduce a To Do type, carefully consider its naming convention. Refer to
System Data Naming Convention for more information.
Description of Page
Enter a unique To Do Type and Description for the To Do type.
Owner indicates if this entry is owned by the base package or by your implementation (Customer Modification).
Use the Detailed Description to provide further details related to the To Do Type.
Enter the default
Priority of To Do entries of this type in respect of other To Do types. Refer to
The Priority Of A To Do Entry for more information.
For To Do Type Usage, select Automatic if To Dos of this type are created by the system (i.e., a background process or algorithm). Select Manual if a user can create a To Do of this type online.
Define the Navigation Option for the page into which the user is transferred when drilling down on a To Do entry of this type.
Use
Creation Process to define the background process, if any, that is used to manage (i.e., create and perhaps complete) entries of this type. A
Creation Process need only be specified for those To Do types whose entries are created by a background process. Refer to
To Do Entries Created By Background Processes for more information.
Use
Routing Process to define the background process that is used to download entries of a given type to an external system, if any. A
Routing Process need only be specified for those To Do types whose entries are routed to an external system (e.g., an Email system or an auto-dialer). Refer to
To Do Entries May Be Routed Out Of The System for more information.
Use Message Category and Message Number to define the message associated with this To Do type's entries. Note: this message will only be used if the process that creates the To Do entry does not supply a specific message number. For example, the process that creates To Do entries that highlight bill segments that are in error would not use this message; rather, the entries are marked with the message associated with the bill segment's error.
Use the characteristics collection to define a Characteristic Type and Characteristic Value common to all To Do entries of this type. You may enter more than one characteristic row for the same characteristic type, each associated with a unique Sequence number. If not specified, the system defaults it to the next sequence number for the characteristic type.
Parent topic
