Maintaining the Web Service Catalog
Refer to
Oracle Integration Cloud Catalog for an overview of web service catalog functionality.
To add or remove services that are reported to the OIC catalog, navigate to the portal using > >
The Catalog by Class zone provides the list of classes (REST and SOAP). Broadcast the web service class that you want to work with.
The Catalog zone provides a list of services that are currently in the catalog based on the web service class chosen. Users may use this zone to remove services from the catalog.
The Candidate Services zone provides a list of external systems and inbound web services that are not currently linked to the catalog. Users may use this zone to add services to the catalog. The inbound web services will be limited to those with the same web service class as the one broadcast. All external systems are shown regardless of the web service class because there is no web service class configuration on external systems.. The expectation is that implementers will create the external system to include either only REST or only SOAP services and will know which external system to include in which catalog. For the SOAP web service class, if XAI inbound services are applicable, they are also visible.
For inbound SOAP web services and XAI inbound services, they may be selected for the SOAP catalog at any time. However, only
deployed services are returned to the catalog by the OIC adapter.
Parent topic
