Migration Transaction Portal
This page appears after drilling into a specific migration transaction from the migration data set portal or from the migration object portal.
Refer to
Importing and Applying a Migration for an overview of the import process.
The following zones are visible on the main tab:
• Migration Transaction. This zone contains display-only information about the selected record. Please see the zone’s help text for information about this zone’s fields.
• Migration Transaction Objects. This zone lists the objects that are related to the data set. To see more information about a specific migration object, click the hypertext for its ID. This brings you to the
Migration Object portal. A user may choose to update the status of one or more records by checking the records and clicking
Approve,
Reject or
Needs Review accordingly.
• Entity Summary. This zone provides a summary count of all migration objects included in the current transaction across the various statuses.
Parent topic
