Defining Distribution Codes
The Distribution Code portal is used to display and maintain distribution codes.
You can access the portal from Admin, select D, then select Distribution Code.
Distribution Code List: This zone lists all distribution code records. Broadcast a record to display the details of the selected record.
Distribution Code: This zone displays information about the selected distribution code.
