Defining Overtime Types
The Overtime Type portal is used to display and maintain overtime types.
You can access the portal from Admin, select O, then select Overtime Type.
Overtime Type List: This zone lists all labor earning type records. Broadcast a record to display the details of the selected record.
Overtime Type: This zone provides information about the selected overtime type.
