Publishing Data as Services in the ArcGIS Server
After importing the datasets, publish the respective map documents as map / feature services in the ArcGIS server.
For more information about publishing a map document as a map service, refer to ESRI ArcGIS information.
For a quick reference on how to create a Work Locations Map service, please refer to the below steps:
1. Create a map document using the Work Locations dataset.
2. In ArcCatalog, right-click Work Locations. From the content menu, click Share as Service.
3. In the Share as Service wizard, select Publish a Service, and then click Next.
4. From the Choose a Connection drop-down list, select ArcGIS Server.
5. Enter the service name with which the service has to be published. Make sure the name is updated in ESRI Integration Master Configuration portal in Oracle Utilities Work and Asset Management.
6. Click Next to proceed.
7. Enter the folder path and then click Continue.
8. In the Service Editor wizard, select Feature Access Capability.
9. Click Publish to publish the map document as a feature service in ArcGIS Server.
