Extending Asset Statuses
If your implementation needs to create a new Asset Lifecycle BO with a status which differs from the base package, you can choose to create them by extending W1-AssetDisposition. With this extension, note the following:
‘assetRelationship’ on the Asset Disposition has 3 values: Installed, Attached, and Not Installed.
Installed is applicable to assets when they are installed in service.
Attached is applicable to components when they are attached to an asset.
Not Installed is applicable when assets or components are in other statuses (in store, in receipt, in repair, rejected, or retired).
Since the assetRelationship is in a Character Large Object (CLOB), the base package uses a naming convention using the asset disposition code. The first two characters should be ‘IN’ for installed, ‘AT’ for attached, and ‘NI’ for not installed.
