Maintaining Material Issue
The Material Issue portal is used to display and maintain material issue records.
You can access the portal from Menu, select Inventory, then select Material Issue. You are brought to a query portal with options for searching for a material issue record. The query search displays a list of material requests. Once a material request record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Parent topic
