Maintaining Stock Items
The Stock Item portal is used to display and maintain a stock item record.
You can access the portal from Menu, select Inventory, then select Stock Item. You are brought to a query portal with options for searching for a specific stock item. Once a stock item has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Stock Item: This zone displays information about the selected stock item.
Stock Item Availability: This zone enables broadcasting of stock item availability per storeroom for the stock item record.
Unlink Specification: This zone removes the specification from the stock item record.
Link Specification: This zone links the specification to the stock item record which enables the stock item to be used to track the associated asset.
Attachments: This zone enables users to manage all types of attachments for the stock item record.
Standard Notes: This zone lists the standard notes associated with the stock item record and enables the viewing of standard note information.
Notes: This zone displays any notes associated with the stock item record.
Referencing Compatible Units: This zone lists the compatible units that reference the current compatible unit.
The following zones may appear as part of the portal’s Bill of Materials tab page:
BOM Tree: This zone displays a hierarchy tree view of the stock item.
Bill Of Materials: This zone displays information about the bill of material associated with the selected stock item record.
Referencing BOM’s: This zone enables broadcasting of referenced parts for the stock item.
Notes: This zone displays any notes associated with the BOM associated with this stock item record.
