Defining Foreign Key References
The topics in this section describe the transaction that allows you to define foreign key references.
To setup a foreign key reference, open > >
Use the Foreign Key Reference Query portal to search for an existing foreign key reference. Once a foreign key reference is selected, you are brought to the maintenance portal to view and maintain the selected record.
CAUTION:
Important! If you introduce a new foreign key reference, carefully consider its naming convention. Refer to
System Data Naming Convention for more information.
Description of Page
Enter an easily recognizable FK (foreign key) Reference code and Description for the record.
Enter the name of the Table whose primary key is referenced. After selecting a Table, the columns in the table's primary key are displayed adjacent to Table PK Sequence.
Use
Navigation Option to define the page to which the user will be transferred when they press the go to button or hyperlink associated with the referenced entity. Refer to
Navigation Information Is Dynamically Derived for more information on how this is used.
The Info Program Type indicates whether the default program that returns the standard information description is Java or Java (Converted), meaning it was converted into Java.
Note:Java (Converted) program types are not applicable to all products.
Use Info Program Name to enter the Java class / program name.
Refer to
Information Description Is Dynamically Derived for more information on the info program is used.
View the source. If the program is shipped with the base package, you can use the adjacent button to display the source code of this program in the
Javadocs viewer.
Use Context Menu Name to specify the context menu that appears to the left of the value.
Context Menu Name is not applicable to user interface elements displaying a generic collection using a foreign key characteristic type. It is only applicable for pages utilizing the foreign key compound element type for fixed page user interface and for data displayed in a portal based user interface where the foreign key reference is defined as an attribute for an element. Report parameters that reference foreign key characteristics are an example of a user interface where a context menu is not displayed even if the foreign key reference defines one.
Use
Search Zone to define the search zone that opens when a user searches for valid values when the foreign key reference is configured as an input field on a portal based page. Refer to
Search Options for more information.
Use
Search Navigation Key to define the search page that will be opened when a user searches for valid values on a user interface that is a fixed page. Refer to
Use Search Type to define the default set of search criteria used by the Search Navigation Key's search page.
Use Search Tooltip to define a label that describes the Search Navigation Key's search page.
Note:Search Type and Search Tooltip. These attributes are only applicable to user interface elements utilizing the foreign key compound element type on fixed page user interfaces. Report parameters that reference foreign key characteristics are an example of a user interface where this information is not used even if the foreign key reference defines them.
Parent topic
