Working with the Revision Control Portal
The Revision Control portal lists information about each version of a revision controlled object.
You can navigate to the Revision Control portal from either a link in the Revision Control dashboard zone or by going to Revision Control portal through Admin.
If you want to find the Revision History entry for an earlier version or deleted object, you must search for the object using the Revision Control Search portal. Once you select the desired entry, you can restore a previous version of the object clicking Restore in the row for the version that you want to restore. You can also see the details of each version by clicking the broadcast icon for that version.
See
Working with Revision Control Zones for more information about tasks that can be performed through Revision Control.
Parent topic
