How to Restart Failed Jobs and Processes
Every process in the system can be easily restarted if it fails (after fixing the cause of the failure). All you have to do is resubmit the failed job; the system handles the restart.
Parent topic
Understanding Background Processes
This site works best with JavaScript enabled
