Groovy Member Steps
Note:Server based scripts only. This step type is not applicable to BPA scripts.
Groovy Member steps provide a free format text area where you can enter Groovy code.
Enter a description of the code block in the Text field. Click the adjacent icon to open a window providing more space for entering text.
Enter your code in the Edit Data Text field. Click the adjacent icon to open a window providing more space for editing the code.
While it is possible to set up multiple steps of type
Groovy Member the system treats these steps as a single class for compilation and execution purposes. Refer to the topic
Using Groovy Within Scripts for more information.
Parent topic
