Move Data Steps
Move data steps allow you to move data (from a source to a destination). The following additional fields are required for Move data steps:
Source Field Type, Source Field Name and Source Field Value define what you're moving. The following points describe each field type:
• Context Variable. Use this field type in a plug-in or service script if the source value is a variable initiated in a higher level script. This is only applicable to Service Scripts and Plug-in Scripts.
• Current To Do Information. Use this field type when the source value resides on the current To Do entry. Refer to
How To Use To Do Fields for instructions on how to define the appropriate
Field Name. This is only applicable to BPA Scripts.
• Data Area. Use this field type when the field being compared is one that you put into one of the script's data areas in an earlier step.
Field Name must reference both a data area structure name as well as the field, for example "parm/charType". Refer to
How To Reference Fields In Data Areas for instructions on how to construct the appropriate
Field Name.
• Global Context. Use this field type when the source value is a
global context variable. This is only applicable to BPA Scripts.
• Page Data Model. Use this field type when the source value resides on any of the tab pages in the
object display area (i.e., the source field doesn't have to reside on the currently displayed tab page, it just has to be part of the object that's currently displayed). Refer to
How To Find The Name Of Page Data Model Fields for instructions on how to find the appropriate
• Portal Context. Use this field type when the source value is a variable in the portal context. This is only applicable to BPA Scripts.
• Predefined Value. Use this field type when the source value is a constant value defined in the script. When this field type is used, use
Source Field Value to define the constant value. Refer to
How To Use Constants In Scripts for instructions on how to use constants.
Note:Concatenating fields together. You can also use
Predefined Value if you want to concatenate two fields together. For example, let's say you have a script that merges two persons into a single person. You might want this script to change the name of the person being merged out of existence to include the ID of the person remaining. In this example, you could enter a
Source Field Value of
%ONAME merged into person %PERID (where
ONAME is a field in temporary storage that contains the name of the person being merged out of existence and
PERID contains the ID of the person being kept). Refer to
How To Substitute Variables In Text for a description of how you can substitute field values to compose the field value.
• Temporary Storage. Use this field type when the source value is a field that you put into temporary storage in an earlier step. The Field Name must be the same as defined in an earlier step.
• User Interface Field. Use this field type when the source value resides on the currently displayed tab page. Refer to
How To Find The Name Of User Interface Fields for instructions on how to find the appropriate
Destination Field Type and Destination Field Name define where the source field will be moved. The Field Type defines where the field is located. The Field Name defines the name of the field. The following points describe each field type:
• Context Variable. Use this field type in your plug-in or service script if you use a variable to communicate information to a lower level service script or schema. This is not applicable to BPA Scripts.
• Data Area. Use this field type when the destination field resides on one of the scripts data areas.
Field Name.
• Page Data Model. Use this field type when the destination field resides on any of the tab pages in the
object display area (i.e., the field populated doesn't have to reside on the currently displayed tab page, it just has to be part of the object that's currently displayed). Refer to
• Portal Context. Use this field type when the destination to be updated is in the current portal context. This is only applicable to BPA Scripts.
• Temporary Storage. Use this field type when the destination field resides in temporary storage. Use
Field Name to name the field in temporary storage. Use
Field Name to name the field in temporary storage. Refer to
How To Name Temporary Storage Fields for more information.
• User Interface Field. Use this field type when the destination field resides on the currently displayed tab page. Refer to
Note:Conditional field types. The field types Current To Do Information, Page Data Model and User Interface Field are only applicable to BPA scripts.
Parent topic
