Configure the System to Invoke BI Publisher Real-time
The base product provides an
installation algorithm plug-in spot called Reporting Tool. This plug-in spot should contain an algorithm that invokes the third party reporting tool real-time.
For BI Publisher, the system provides an algorithm type called F1-BIPR-INV, which invokes BI Publisher.
These algorithms rely on information defined in the
Reporting Options table: the reporting server, reporting folder and the user name and password for accessing the reporting tool. The values in the reporting options should have been set up when the system was installed. Contact your system administrator if there are any problems with the values defined on the reporting options.
To use the algorithm types to invoke BI Publisher, perform the following steps:
• Create an
algorithm for the appropriate algorithm type.
• On the
installation options, add an entry to the algorithm collection with an algorithm entity of
Reporting Tool and indicate the algorithm created in the previous step.
Parent topic
