Defining Compatible Unit Usages
The Compatible Unit Usage portal is used to display and maintain compatible unit usages.
You can access the portal from Admin, select C, then select CU Usage.
CU Usage List: This zone lists all compatible unit usage records. Broadcast a record to display the details of the selected record.
CU Usage: This zone provides information about the selected compatible unit usage, such as the CU Usage Description and its associated Cost Centers.
