Defining Failure Modes
The Failure Mode portal is used to display and maintain failure modes.
You can access the portal from Admin, select F, then select Failure Mode.
• Failure Mode List: This zone lists all failure mode records. Broadcast a record to display the details of the selected record.
• Failure Mode: This zone provides information about what has failed, such as arcing, binding, backward, and so on.
• Included on Failure Profile: This zone lists the failure profiles associated with a particular failure mode.
Parent topic
