Importing Data to Geodatabase
After the Geodatabase is set up, make sure that the necessary customer specific datasets are imported
To import the work locations dataset:
1. Download the Oracle Utilities Work and Asset Management V2.4.0.0.0 ESRI Integration component from the Oracle Utilities Work and Asset Management V2.4.0.0.0 package.
2. Copy the file to the server where ArcGIS is installed and unzip it.
3. Navigate to the XML workspace file located at /metadata/ xmlWorkspaceDocument/WORKLOCATIONS.XML.
4. Copy the workspace file to the relevant destination folder.
5. Select Database Connections in the Catalog.
6. To import the XML workspace document:
a. Select Schema Only in the import options.
b. Specify the path of the work locations XML file.
7. Once the import process is complete, the Contents tab displays the WorkLocationDataset imported into the Geodatabase.
Note that the Map Notes dataset configuration is optional. However, to display a Map Notes layer, any layer dedicated to capture notes/redlining can be used. Map Notes is a customer specific layer and Oracle Utilities Work and Asset Management does not own/manage it and is not delivered as part of base product. To create a feature class in Geodatabase, refer to ESRI ArcGIS instructions.
Register data with the ArcGIS Server using Manager. For instructions refer to ESRI ArcGIS.
Parent topic
