Installing the ArcGIS Web Adapter
If web maps are set up with ArcGIS Online, ArcGIS web adaptor installation is not required. However, if ArcGIS portal is used to set up the intended web maps, then the ArcGIS web adaptor should be installed
For information about installing and configuring ArcGIS web adapter, refer to ESRI ArcGIS information.
