Maintaining Digital Asset Service Tasks
The Service Task portal is used to display and maintain digital asset service tasks.
You can access the portal from Menu, then select Service Task. You are brought to a query portal with options for searching for a specific record. Once a service task has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Service Task: This zone displays general information about the service task.
Parent topic
