Maintaining Metered Service Points
The Metered Service Point portal is used to display and maintain metered service points.
Refer to
About Metered Service Pointsfor more information.
You can access the portal from Menu, select Digital Asset Management, then select Metered Service Point. You are brought to a query portal with options for searching for a specific record. Once a metered service point has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Metered Service Point: This zone displays basic information for this metered service point.
• Program Subscriptions: This zone lists program subscriptions associated with the metered service point.
Parent topic
