Maintaining Material Returns
The Return portal is used to display and maintain receipt return records.
You can access the portal from Menu, select Inventory, then select Material Return. You are brought to a query portal with options for searching for a material return record. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Return: This zone displays information about the material return.
• Material Return Quick Add: This zone enables the addition of material to be returned.
• Open Return Lines: This zone displays the open return lines associated with the material return.
• Closed Return Lines: This zone displays the closed return lines associated with the material return.
• Stock Item Inventory: This zone displays stock item inventory information after broadcasting an open return line.
• Stock Item Availability: This zone displays upon broadcasting an open return line and displays stock item inventory information per storeroom.
Parent topic
