Defining Device Location Types
You use the Device Location Type portal to display and maintain device location types.
Refer to Understanding Device Location Types for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Device Location Type.
Device Location Type List: This zone lists all device location type records. Broadcast a record to display the details of the selected record.
Device Location Type: This zone provides information about the selected device location type.
