Defining Digital Asset Service Task Types
You use the Service Task Type portal to display and maintain digital asset service task types.
Refer to Understanding Digital Asset Service Task Types for more information.
You can access the portal by selecting Admin, select General, then select Service Task Type.
Service Task Type List: This zone lists all service task types defined in the system. Broadcast a record to display the details of the selected record.
