Defining Program Subscription Contact Types
You use the Contact Type portal to display and maintain device location types.
Refer to Understanding Program Subscription Contact Types for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Program Subscription Contact Type.
Contact Type List: This zone lists all program subscription contact type records. Broadcast a record to display the details of the selected record.
Contact Type: This zone displays the selected program subscription contact type.
