Enable USER_LOCK Package
For inbound web services to work, the USER_LOCK must be enabled at the database level. This is a one-time step. If this is not already enabled, enable it using the following steps:
1. Login as SYS user.
2. On SQL prompt run.
@<ORACLE_HOME>/rdbms/admin/userlock.sql
3. Grant permission by running following SQL:
grant execute on USER_LOCK to public;
Note that grant can also be made to the database user that the application connects to (for example, cisuser), instead of ‘public’.
