Installation Types
The first step in the installation procedure is to determine the installation type that meets your business requirements. The following are the possible installation types:
• Initial Install - a database with no demo data
• Upgrade Install - a database upgrade from a previous release
• Demo Install - a database populated with demo data
Refer to Supported Database Platforms for information about the supported platforms on which Oracle Utilities Operational Device Management is verified to operate.
Initial Install
To install Oracle Utilities Operational Device Management V2.4.0.0 for the first time refer to the
Installing the Oracle Utilities Operational Device Management Database - Initial Installation section for complete instructions.
Upgrade Install
This is applicable for customers who already have Oracle Utilities Operational Device Management V2.2.0.6.0 or V2.3.0.0.0 installed.
To upgrade to Oracle Utilities Operational Device Management V2.4.0.0.0, follow instructions in the
Upgrading the Oracle Utilities Operational Device Management Database section.
Demo Install
For a demo installation, follow the instructions in
Installing the Database- Demo Environment.
