Table | Description | Table Type |
F1_ATTACHMENT_K | Attachment Key | Transaction |
F1_CRYPTO_KEY | Key Ring Key | Admin |
F1_CRYPTO_KEY_RING | Key Ring | Admin |
F1_CRYPTO_KEY_RING_L | Key Ring Language | Admin |
F1_CRYPTO_KEY_RING_LOG | Key Ring Log | Admin |
F1_CRYPTO_KEY_RING_LOG_PARM | Key Ring Log Parameter | Admin |
F1_CUBE_TYPE | Cube Type | Admin |
F1_CUBE_TYPE_L | Cube Type Language | Admin |
F1_CUBE_VIEW | Cube View | Transaction |
F1_CUBE_VIEW_L | Cube View Language | Transaction |
F1_CUBE_VIEW_LOG | Cube View Log | Transaction |
F1_CUBE_VIEW_LOG_PARM | Cube View Log Parameters | Transaction |
F1_DEPLOYMENT_K | Deployment Key | Transaction |
F1_ERASURE_SCHED | Object Erasure Schedule | Transaction |
F1_ERASURE_SCHED_K | Object Erasure Schedule Key | Transaction |
F1_ERASURE_SCHED_LOG | Object Erasure Schedule Log | Transaction |
F1_ERASURE_SCHED_LOG_PARM | Object Erasure Schedule Log Parameter | Transaction |
F1_MDT_K | Mobile Data Terminal Key | Transaction |
F1_MIGR_OBJ_SQL_PK | Migration Object SQL Primary Key | Transaction |
F1_PROC_DEFN | Process Flow Type | Admin |
F1_PROC_DEFN_L | Process Flow Type Language | Admin |
F1_PROC_NEXT_PANEL | Next Panel | Admin |
F1_PROC_PANEL | Process Panel | Admin |
F1_PROC_STORE | Process Flow | Transaction |
F1_PROC_STORE_DTL_ELEMENTS | Process Flow Detail Elements | Transaction |
F1_PROC_STORE_K | Process Flow Key | Transaction |
F1_PROC_STORE_LOG | Process Flow Log | Transaction |
F1_PROC_STORE_LOG_PARM | Process Flow Log Parameters | Transaction |
F1_REMOTE_MSG_K | Mobile Remote Message Key | Transaction |
F1_STATS_SNPSHT_K | Statistics Snapshot Key | Transaction |
F1_ATTACHMENT | Attachment |
F1_DEPLOYMENT | Deployment |
F1_MDT | Mobile Data Terminal |
F1_REMOTE_MSG | Mobile Remote Message |
F1_STATS_SNPSHT | Statistics Snapshot |
Table |
F1_IWS_SVC_OPER_L |
Table |
F1_CRYPTO_KEY_RING_LINK |
Table | Column | Required |
CI_BATCH_RUN | END_DTTM | N |
CI_BATCH_RUN | START_DTTM | N |
CI_COUNTRY | ADDR1_USG_FLG | Y |
CI_COUNTRY | ADDR2_USG_FLG | Y |
CI_COUNTRY | ADDR3_USG_FLG | Y |
CI_COUNTRY | ADDR4_USG_FLG | Y |
CI_COUNTRY | CITY_USG_FLG | Y |
CI_COUNTRY | COUNTY_USG_FLG | Y |
CI_COUNTRY | GEO_CODE_USG_FLG | Y |
CI_COUNTRY | HOUSE_TYPE_USG_FLG | Y |
CI_COUNTRY | IN_CITY_LIM_USG_FLG | Y |
CI_COUNTRY | NUM1_USG_FLG | Y |
CI_COUNTRY | NUM2_USG_FLG | Y |
CI_COUNTRY | POSTAL_USG_FLG | Y |
CI_COUNTRY | STATE_USG_FLG | Y |
F1_ATTACHMENT | ATTACHMENT_EXT_ID | N |
F1_ATTACHMENT | COMMENT_LONG | N |
F1_IWS_SVC | RESOURCE_CAT_XFLG | N |
F1_IWS_SVC | WEB_SVC_CLASS_FLG | Y |
F1_IWS_SVC_OPER | RESOURCE_URI | N |
F1_IWS_SVC_OPER | REST_HTTP_METHOD_FLG | N |
F1_SVC_CATALOG | WEB_SVC_CLASS_FLG | Y |
Table | Description | Type of Table |
F1_DEPLOYMENT | Deployment | Transaction |
F1_DEPLOYMENT_ITEM | Deployment Item | Transaction |
F1_DEPLOYMENT_ITEM_METADATA | Deployment Item Meta Data | Transaction |
F1_DEPLOYMENT_PART | Deployment Part | Master |
F1_DEPLOYMENT_PART_L | Deployment Part Language | Master |
F1_DEPLOYMENT_TYPE | Deployment Type | Master |
F1_DEPLOYMENT_TYPE_L | Deployment Type Language | Master |
F1_DEPTYP_DEPPART | Deployment Type / Deployment Part | Transaction |
F1_DEPTYP_MDT_TYPE | Deployment Type / MDT Type | Transaction |
F1_DEPTYP_MSG_CAT | Deployment Type Message Category | Transaction |
F1_DEPTYP_USR_GRP | Deployment Type User Group | Transaction |
F1_MDT | Mobile Data Terminal | Transaction |
F1_MDT_CHAR | Mobile Data Terminal Characteristics | Transaction |
F1_MDT_TYPE | Mobile Data Terminal Type | Master |
F1_MDT_TYPE_CHAR | Mobile Data Terminal Type Characteristics | Master |
F1_MDT_TYPE_L | Mobile Data Terminal Type Language | Master |
F1_MOB_COMP_CHAR | Mobile Component Characteristics | Admin - System |
F1_MOB_COMP_CNT | Mobile Component Content | Admin - System |
F1_MOBILE_COMPONENT | Mobile Component | Admin - System |
F1_MOBILE_COMPONENT_L | Mobile Component Language | Admin - System |
F1_REMOTE_MSG | Remote Message | Transaction |
F1_REMOTE_MSG_CHAR | Remote Message Characteristics | Transaction |
F1_REMOTE_MSG_LOG | Remote Message Log | Transaction |
F1_REMOTE_MSG_LOG_PARM | Remote Message Log Parameters | Transaction |
F1_WEB_CAT_L | Web Service Category Language | Admin - System |
F1_WEB_CAT_INCL_SVC | Web Service Category - Included Services | Admin - System |
F1_WEB_CAT | Web Service Category | Admin - System |
Table |
F1_IWS_ANN_CHAR |
F1_IWS_ANN_TYPE_CHAR |
CI_MD_SVC | APP_SVC_ID | N |
F1_OUTMSG | BO_XML_DATA_AREA | N |
F1_OUTMSG_TYPE | OUTMSG_PRIOR_FLG | Y |
F1_OUTMSG_TYPE | OWNER_FLG | N |
F1_OUTMSG_TYPE | TYPE_BUS_OBJ_CD | N |
F1_OUTMSG_TYPE_L | OWNER_FLG | N |
