Customizing Centralized Properties
The template process, which is part of the initialSetup step, will look at the files etc/cm_properties.ini (this can be created as a Customer Customization). If the file exists, the content will be processed for the relevant properties.
NOTE: Product teams might use this file format: etc/<PROD>_properties.ini (where <PROD> could be one of the list of installed products included in etc/PRODUCT.txt). If it exits it will be processed as well.
Example cm_properties.ini
The following denote the type of entries that could be included into cm_properties.ini and relevant type of action:
• <PROPERTIES_FILE>:<PROPERTY_NAME>=<VALUE>
• Override <PROPERTY_NAME> in <PROPERTIES_FILE> with <VALUE> if exists.
• Insert <PROPERTY_NAME> in <PROPERTIES_FILE> with <VALUE> it doesn't exists.
• <PROPERTY_NAME>=<VALUE>
• Override <PROPERTY_NAME> in all property files with <VALUE>, if <PROPERTY_NAME> exists
• <PROPERTIES_FILE>:<PROPERTY_NAME>=[DELETE]
• Remove <PROPERTY_NAME> from <PROPERTIES_FILE> if exists.
• <PROPERTY_NAME>=[DELETE]
• Remove <PROPERTY_NAME> from all property files, if <PROPERTY_NAME> exists.
Template example -> hibernate.service.properties.template:
hibernate.user = @DBUSER@
hibernate.pass = @DBPASS@
hibernate.ucp.validate_connection = true
Sample ENVIRON.INI
The following is an example ENVIRON>INI:
DBUSER=cisadm
Sample cm_properties.ini
The following is the content of an example cm_properties.ini:
hibernate.service.properties.template:hibernate.user=clouduser
hibernate.password=cloudpwd
hibernate.iws.properties.template:hibernate.user=clouduser
hibernate.service.properties.template:hibernate.ucp.validate_connection=[DELETE]
hibernate.service.properties.template:new.property=test
Result of hibernate.service.properties generated properties file
The following is a sample result of hibernate.service.properties generated properties file:
### The following line was overridden because <PROD>_properties.ini file setting:
### The following line was deleted because <PROD>_properties.ini file setting:
# hibernate.ucp.validate_connection = true
### The following line was appended because <PROD>_properties.ini file setting:
new.property = test
Result of hibernate.iws.properties generated properties file
The following is a sample result of hibernate.iws.properties generated properties file:
