Before You Upgrade
Review the list of operating system, application server and database server combinations that this version of Oracle Utilities Operational Device Management is certified to operate on, in the
Supported Platforms and Hardware Requirements section.
For further assistance, contact My Oracle Support before you upgrade.
Note: If you are upgrading a previously installed application server, it is recommended that you make a backup before you start the upgrade procedure. The upgrade installation will remove your existing environment including your configurations.
