Value | Description |
User ID | Authorization User to track. |
Audit Table | The name of the table containing the audit information. |
Creation Start Date/Time and Creation End Date/Time | Date and time range to limit the records returned. |
Result | Description |
Row Creation Date | Date and time the changes were made. |
Audited Table Name | Name of table that was audited. |
Primary Key | Record key of the change. |
Audited Field Name | Name of field that was changed. |
Audit Action | Action that was recorded with change (Insert, Update or Delete). |
Field Value Before Audit | The field value before the change was made. |
Field Value After Audit | The field value after the change was made. |
