Configuring OAuth for the Mobile Framework
Note: This capability is only available for selected Oracle Utilities SaaS Cloud Services.
Note: For customers using the included identity solution in the Oracle Utilities SaaS Cloud Services will not need to configure this capability as it is automatically configured as part of the provisioning process. Manual configuration is only required for externalized identity solutions.
To configure the OAuth capability for the Mobile Framework, create or update the Master Configuration for the Mobile Identity Configuration. In this configuration, the following must be configured:
Field
Description
IDCS URL
The URL of the identity solution used on the cloud instance.
IDCS Client Identifier
The mobile application identifier as configured in the identity solution used on the cloud instance.
IDCS Scope
Scope of the mobile application as configured in the identity solution used on the cloud instance.
Mobile Application URL
Full URL of mobile application that this capability is scoped to. This is only provided if the default URL is not used.
