Defining Display Icons
Icons are used to assist users in identifying different types of objects or instructions. A limited number of control tables allow administrative users to select an icon when they are configuring the system. Select Admin > System > Display Icon Reference to maintain the population of icons available for selection.
Description of Page
Each icon requires the following information:
• Display Icon is a code that uniquely identifies the icon.
• Icon Type defines how big the icon is (in pixels) or if it is a Scalable Vector Graphic (SVG) icon.
• Description contains a brief description of the icon.
• URL describes where the icon is located. Your icons can be located on the product's web server or on an external web server.
• To add a new icon to the product web server, place it under the /cm/images directory under the DefaultWebApp. Then, in the URL field, specify the relative address of the icon. For example, if the icon's file name is myIcon.gif, the URL would be /cm/images/myIcon.gif.
◦ If the icon resides on an external web server, the URL must be fully qualified (for example, http://myWebServer/images/myIcon.gif).
◦ Owner indicates if this icon is owned by the base product or by your implementation (Customer Modification). This information is display-only.
