Using the Algorithm Viewer List Panel
The list panel displays a list of algorithm types and their related algorithms, grouped by their plug-in spot.
In the list panel, you can navigate using the following options:
• Click the algorithm plug-in spot description to display information about the plug-in spot in the detail panel.
• Click the right pointer
![Right pointer icon Right pointer icon](../ODM_24000/images/91AppViewer057.jpg)
icon to expand a plug-in spot and view its algorithm types and their related algorithms.
• Click the down pointer
![Down pointer icon Down pointer icon](../ODM_24000/images/91AppViewer058.jpg)
icon to collapse the list of algorithm types for a plug-in spot.
• Click the algorithm type name to display information about the algorithm type in the detail panel.
• Click the algorithm name to display information about the algorithm in the detail panel.
Parent topic
