Performance Target Category Lookup
Refer to About Performance Targets for an overview of performance target functionality.
Each Performance Target Type is associated with a unique Performance Target Category. The categories are defined as an extendable lookup.
Navigate to the Extendable Lookup portal. Search for and select the Performance Target Category business object. Define values that are appropriate to the categories your implementation is assigning for the performance target types in use. In some cases, an edge application may already have delivered the appropriate performance target category for your use
Refer to the embedded help for more information about configuring this object.
