JNDI Server
If using JMS to communicate outbound messages, define a new JNDI Server. Open Admin > Integration > JNDI Server.
Description of Page
Enter a unique JNDI Server and Description.
Indicate the Provider URL to indicate the location of the JNDI server. A variable may be used in place of all or part of the URL. The variable must be predefined in the substitution variable property file. The value here should enclose the variable name with @. Refer to Referencing URIs for more information.
Indicate the Initial Context Factory, which is a Java class name used by the JNDI server provider to create JNDI context objects.
