Advanced Algorithm Tips
Initiating Actions that Cannot be Rolled Back
If you have an algorithm that creates a sync request or performs some other logic that could cause a message to be sent and cannot be rolled back, you should be sure to cater for warnings in the design.
The algorithm should be performed after all validations that could accumulate warnings.
The algorithm should include a step to call the Business Service F1-CheckWarning and see if any warnings have been accumulated.  If so, don't perform the action.  It means that the user will get a warning and if they click "OK", all the processing will happen again, but this time without accumulating any warnings.  Refer to the plug-in script F1-GnChgDCap for an example.
