Defining Process Flow Types
This portal is used to maintain process flow types.
You can access the portal from the > >
The following zones may appear as part of the portal's Main tab page
• Process Flow Type List. This zone lists all process flow types. Broadcast a record to display the details of the selected process flow type.
• Process Flow Type. This zone provides information about the selected process flow type.
Parent topic
