Multiple Owners In A Single Database
The conversion process relies on the following table owner configuration in the system database:
The production owner is linked to the tables used by your production system. These tables have an owner ID of CISADM.
The staging owner is linked to the tables into which you insert your pre-validated data. These tables have an owner ID of CISSTG.
The staging owner schema is almost identical to the production schema, with the following exceptions:
Control tables are not actual tables in staging but rather views to the corresponding tables in production.
Conversion specific tables designed solely to support the conversion process exist only in the staging schema. For example, tables that manage key assignment and XML resolution.
This section provides some high level concepts related to these table owners.
Validation Always Uses Production Control Data
When the validation batch processes run against your staging data, they validate the staging data against the production control tables (and insert errors into the staging error table). This means that the SQL statements that access / update entities needs to use the staging owner whereas the SQL statements that access control tables need to use the production owner. But notice that when these same validation batch processes run against production, the SQL statements will never access the staging owner. Rather, they all point at the production owner.
This is accomplished as follows:
A separate application server must exist for each owner. Each application server points at a specific database user ID.
In a Cloud installation, the application server may only point to a specific database user ID at any point in time. Refer to the “Data Conversion Support for Cloud Implementations” for more information about switching owners.
The database user ID associated with the staging owner uses CISSTG as the owner for the master and transaction tables, but it uses CISADM as the owner of the production control tables.
The database user ID associated with the production owner uses CISADM as the owner for all tables.
You may wonder why we went to this trouble. There are several reasons:
We wanted to reuse the validation logic that exists in the programs that validate your production data. In order to achieve this, these programs must sometimes point at the staging owner, and other times they must point at the production owner (and this must be transparent to the programs otherwise two sets of SQL would be necessary).
We wanted to let you use the application to look at and correct staging data. This can be accomplished by creating an application server that points at your staging database with the ownership characteristics described above.
We wanted the validation programs to be able to validate your production data (in addition to your staging data). Why would you want to validate production data if only clean data can be added to production? Consider the following scenarios:
After an upgrade, you might want to validate your production data to ensure your pre-existing user-exit logic still works.
You may want to conduct an experiment of the ramifications of changing your validation logic. To do this, you could make a temporary change to user exit logic (in production) and then run the validation jobs on a random sample basis.
You forget to run a validation program before populating production and you want to see the damage. If you follow the instructions in this document, this should never happen. However, accidents happen. And if they do, at least there's a way to determine the ramifications.
Only Validation Can Work In Both Owners
While the redirection of owner ID's is a useful technique for the validation batch processes, it cannot be used by the key assignment and production insert batch processes? Why, because these processes have to access the same tables but with different owners at the same time. They also need to reference conversion specific tables that do not exist in production. For example, the batch process that inserts rows into a table in production must select rows from the staging version of that table, resolve keys from the conversion old key / new key mapping tables and insert the resolved records into the production version of that same table
In staging, a view to production exists for each eligible to conversion table. These views have hard-coded the database owner to point to production. For example, there is a view called CX_​PER that points at person table in production.
The key assignment and insertion programs use these views whenever then need to access production data.
